djsamuel
Aug 19, 2014Nomad
LarryJM wrote:djsamuel wrote:
In what areas should Eternabond be used and when should something like Dicor Self Leveling sealant be used? Or, can Etrnabond be used pretty much everywhere. My trailer has an aluminum roof, but Dicor is used along the perimter of the roof as well as around vents, etc. Is Eternabond an option along the perimeter?
Look thru the Eternabond link in my signature below and READ CAREFULLY ALL the captions since that is where the important info is and you will see that Eternabond can be used in about every area of a trailer. As mention hospital level cleanliness and being extra careful not to pull or put the Eternabond tape under tension along with proper rolling/pressing the tape to activate properly the microsealant are the three CRITICAL pieces in a successful application.
Larry
This is great, loads of good info. Thanks!
