dvitale300
Dec 06, 2016Explorer
Need some help - going on a trip Thursday (well maybe)
Hi - going on a trip Thursday. I have a Starcraft 28BHS (2015). It has a 6 gal Atwood gas water heater.
I can get the heater to kick on and run for 20 minutes (sometimes), but not a lot of hot water. Most of the time, the heater starts and then, after a series of clicks, shuts off. I am thinking that there's a thermostat issue but not sure.
I have switched the propane tanks, furnace and stove work fine. I checked the water connections / valves - no problem that I can see. Water pump is working fine - I can get water to everywhere in the unit.
Is there a way I can "unplug" the cut-off so that I can use the unit on the trip - or am I in the position of having to replace the thermo stuff, etc. (which I probably can't do in time). Just thought I should ask before I cancel the trip. Thanks - david
