mellow wrote:
If the OP had gotten a 450 I wouldn't mention that. The 350 brakes are one of the weak points if you ask me. I just redid the rears and front on mine, new calipers/rotors/pads/flex line. At a minimum I would suggest upgrading the front brakes to a bigger caliper with that much weight.
Hmmm, not a "ford guy", but I've had a couple F250s of that era that I used for construction work. Don't recall the brakes being a weak point. And likely the vast majority of the millions of other owners don't either.
And how, on a 2013 model (think that's what the OP said) would calipers/rotors/pads and flex lines all need replaced, unless the truck was super high miles, abused or rusting out? Sounds like you went to Les Schwab. That's their schtick. They won't do just brake pads, regardless of the vehicle. I needed pads only and was told, over the phone, pads, rotors and calipers must all be replaced....on a 3 year old truck with about 60k miles, that only needed brake pads.
Heck, my personal truck is approaching 180k on original everything except brake pads.
