jwadd's avatar
jwadd
New Maxxis yesterday- not so sure
I need some advice. I bought brand new Maxxis 8008 yesterday at a shop I have never used before. I had to travel 160km as they were the closest shop that has Maxxis brand tires. They are 225/75/15 load range D. They did the install and and balance. All went well and I made it home.
I don't know the exact weight of my trailer. I am guessing around 8000lbs as sticker says unloaded weight before options is 6560lbs. 2008 Keystone Hornet 27BHS.
They inflated these new tires to 45psi with nitrogen. I questioned the young installer about pressure and nitrogen. Said the lower pressure would provide a way smoother ride and they use nitrogen in all their tires as standard practice at that shop. I left assuming this young man had been trained and knew what he was talking about.
Based on reading other posts I am now questioning the tire pressure. Should I add air to cold max of 65psi. We regularly load up for longer 2-3 week trips. 45psi seems low to me and defeats the purpose of load range D tires. It did tow just fine and all tires remained cool coming home. We were loaded for two days and no water.
Advice please.
FYI - our local shop only had Carlisles and another brand I had not heard of.
