New owner with some questions
thinksnow66
We are the proud owners of a 2012 Kestone Laredo 291TG. I down loaded the manual and read through it, but I still have a few questions. I was under the trailer the other day adjusting the brakes and noticed three white / translucent tubes with valves on the end. Two are side by side and one is alone. Im assuming one is a drain for the freshwater tank. What are the others?
Speaking of the brakes, what do you all carry for a jack. I was using a 3 1/2 ton floor jack, with three blocks of wood I was able to get it to reach the frame and get the tires off the ground. What are you all bringing on the road for a jack? I can't imagine traveling with that floor jack.
Is there anything I should be applying to the joint sealents on the roof to stop them from drying out and leaking?
9 REPLIES 9
star_2008
Open the relief valve to let the air out it helps
Marsland
Turn off all sink and shower valves. Open a hot water valve. Allow time for the hot water tank to fill and push water through the open hot water valve. It will take some time. Minute or two. Then close that valve and open the rest of the valves one at a time to purge air from the system.
Also, MAKE SURE HOT WATER TANK IS OFF WHEN EMPTY!!
1 (Re)tired DH
1 Terrific DW
2012 Keystone Bullet 284RLS
2012 Ford F150 S/Crew ECOBoost
ScanGaugeII
Tvov
The on board water pump will prime itself (self priming type of thing), you shouldn't have to worry about that. How long did you let the pump run while "gargling"? It may have just been the air in the pipes getting pushed out. Yes check for valves under sinks and in cabinets, there may be a winterizing valve still closed or set for bypass. I am sure someone here with a better knowledge of your camper will chime in.
As to the jack: When I am home, I use a large rolling floor jack to service the wheels. For on the road, I practiced a tire change using my truck's (F250) jack and it works fine. As mentioned previously, place the jack carefully to avoid any damage. Also, as mentioned, make sure you have the correct size wrench/socket for the trailer lug nuts! I bought a socket specifically for the trailer wheels, and keep it in the truck's glove compartment. I also have a pretty good tool kit I keep in one of the trailer's compartments.
See you on the road!
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
thinksnow66
Thanks fellas,
This morning I drained everything. I have the water tank full of the water bleach solution. I turned on the pump and opened the cold water spigot in the sink but injustice pushing air. There's a gargling sound like the pump can't prime itself. I'm lost at this point. Is there a valve I'm supposed to flip to go from city water to the tank?
Dick_B
Check out Trailer Aid the ramp that gets the bad wheel off the ground. For more info search this Forum for `trailer aid'.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
DutchmenSport
The two lines are your low-point drains, hot and cold water. The third is your fresh water tank.
Jacks? I don't carry any. Never changed a tire myself, never had a flat either. If it happens, we'll just call road side assistance. (AllState Insurance)
I don't think you have anything to worry about on your roof, and should not not worry for a long time. You're camper is still brand new. No need to do anything unless you DO have a problem. If it isn't broken .... don't fix it!
Chuck_Gail
I use Lynx Leveler Blocks on my dual axle, same ones used to level TT at campgrounds. Just build a ramp and pull unflat tire up ramp until flat tire is free. Remember to loosen lug nuts FIRST.
Be sure you have a lug wrench that fits!
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
Farm_Camp
Quick guess are that the two together are your low point drains for the plumbing system one for hot and one for cold... As for jacking. My plan is to use a ramp under the other tire to get the one I need to work on up off the ground (if you have dual axle). People speak highly of Dicor for sealing and Eternabond tape.
TV: 2010 F250 XLT 4X4 SC SB 5.4L 3.73 - "The Blue Monster" (2013-2018) Traded at 100K
TV: 2017 F250 XLT 4X4 CC SB 6.7L PD 3.31 - "The Silver Streak"
TT: 2014 Starcraft Autumn Ridge 329BHU
Our Story...
Places we've camped
donn0128
Two of the lines should be low point drains and the third should be the potable water tank drain.
As for jack? I have a 10 ton hydraulic jack that i use. I also carry the correct socket for the lug nuts, a 4 inch 1/2 inch drive extension and breaker bar. Plus a torque wrench. In an emergency you can some times use the tow vehicles jack. Be sure to only jack under the spring perch.
