Goldstalker
Mar 31, 2014Explorer
Carhlr wrote:
Trucks payload is 1873lbs rear axle is 3:42 tongue weight of TT is 640lbs me wife and 3 kids I looked around I think I'll be right at the limit maybe just under. I drive semi for a living so pulling a Trailer isn't new just wanted to make sure I had enough truck it has trans cooler, oil cooler, tow haul mode manual push button shift if needed I guess ill find out we pick up the new TT in 2 weeks. my main concern was from tongue to end is 35 feet I see the dreaded TT sway on the highway all to often when im passing one. I hope this set up will NOT have the sway
You should be ok. Just pack as light as possible and don't carry fresh water if possible. Also load all you can into the trailer and not the bed of the truck.
