PAThwacker's avatar
PAThwacker
New travel trailer Gulfstream Conquest 323tbr
Got a new to us 2020 Gulfstream Conquest 323 Tbr 11,600 gvw. Way outside of half ton world. Got it delivered to seasonal site while I shop for next tow rig. Been looking only at used gas trucks from GM and ford 3/4 to 1 ton srw. Any 6.0 older gas Chevy or 6.2 ford for this trailer? How about older ford 5.4 3/4 truck?
  • Had a 5.4 in my 98 Expedition. Replaced the head exhaust gaskets, both sides, TWICE. They liked to leak. Cast iron header to aluminum head. Once started leaking it would etch into the aluminum. It only had 60000 miles on it when we sold it after 16 years.
    Having the 5.4 as a base model engine in a Superduty is/was the same as getting the V6 in the F150.
  • Nv_Guy's avatar
    Nv_Guy
    Having owned two 5.4 Fords, I would avoid them, as they will struggle pulling this rig. 6.2 would be a better choice.
  • Not sure where you got your weight info but it seems little high. Although factory numbers are usually low...7500/9800lbs. Either way a 3/4 ton should work for this trailer but I'd never walk away from a 1 ton if it was close in price. Good luck with your new trailer :)
