2012Oudoorsman
Mar 25, 2016Explorer
New Truck 2016 RAM 3500 CCLB
Picked up my new truck on March 1st. It's a 2016 RAM 3500 CCLB Bighorn Cummins/Aisin. Ordered it Dec 26 and came in on Feb. 29. Worked perfect for me as we were mostly through the winter and no real salt was put down due to the mild winter.
Truck has a payload of 4039lbs and a gvwr of 12300. Pretty heavey at 8251lbs but im getting about 2mpg or so better than my 2012 RAM 1500 Outdoorsman with the 5.7l and 3.92 gears.
Haven't really used it yet but I can tell that it will be a huge improvement over the 1500. The 7500lb TT isn't really going to work it but I ordered the truck to be ready for when we upgrade to a fifth wheel.
A couple things I've noticed.
Ride is noticeable stiffer than my FIL 2012 F350 Scab LB and my friends 2013 F350 Screw LB. I aired down tires but still stiffer.
Everything I disliked with my 2012 changed. Location of trailer brake controller and gear selection now also tells you what gear you're in.
The Exhaust brake is awesome but I don't think this will be necessary for me. We do have decent hills but I haven't been on when on the interstate that I accelerates down. This may change when my gvwr FL goes from 13,500 lbs to over 20,000 with a new fifth wheel.
I think it really needs an upper overload like the F350s. With a tounge weight of 750-800lbs it dropped an inch and only had an inch left in the rake before being level. With a payload of 4000lbs I can't imagine it won't sag a good amount. The true test will be when I start loading some green oak firewood on it and we'll see.
