โFeb-26-2017 03:35 PM
โMar-13-2017 01:23 PM
tnrv'er wrote:
Last train, do you have WD hitch ?
โMar-08-2017 08:12 AM
โMar-01-2017 10:38 PM
โMar-01-2017 11:51 AM
NYCgrrl wrote:
The smallest car I've ever heard of in it's weight class for occasional towing of a small TT is some kind of Volkswagen. I need to wander thru the blog to find the version he uses to tow and will get back to you when I find it.
โMar-01-2017 10:13 AM
SoundGuy wrote:Last Train wrote:
Our CAT Scale weights (we weigh regularly) typically show a trailer weight of 4600-4700 lbs. Our tongue weights come in around 480-520 lbs.
Average gross weight for our 2014 192RBS also typically runs ~ 4600 lbs, a bit more those times I may be carrying content in the black tank as well. However, where we differ is gross tongue weight as mine typically averages 600+ lbs (confirmed with my Sherline TW scale) or ~ 13% of it's gross weight and certainly about as little as I'd want to be running. I'm surprised yours is so much less, only ~ 11% which IMO is far too little. As I've done with previous trailers I did move the spare tire to the front pass through cargo compartment and that certainly did help improve gross tongue weight but I'd still prefer a bit more, which I'd probably achieve if I ever upgrade from a single G27 battery on the tongue to a pair of batteries. I suppose so little gross tongue weight may better match the capabilities of your Ridgeline but that's nonetheless awfully light for a trailer averaging ~ 4600 to 4700 lbs loaded and ready to camp.
โMar-01-2017 09:39 AM
โMar-01-2017 09:33 AM
Jebby14 wrote:
as someone intimately familiar with the current ridgeline (im an automation designer and did a lot of the tooling for it) I do not have any desire to own one at their current price point. I think there are several better options. That said, to each their own. If a ridgeline is what your after I hope you get many years of enjoyment out of it. Good luck with whatever you chose.
โMar-01-2017 03:53 AM
โMar-01-2017 02:39 AM
โMar-01-2017 01:59 AM
โFeb-28-2017 07:16 PM
SoundGuy wrote:Jebby14 wrote:
Even the Pilot and the Ridgeline are not really well suited tow vehicles.
Forum member Last Train tows the same trailer I have - a Coachmen Freedom Express 192RBS - with his Honda Ridgeline and as I understand it is quite happy with how it tows his trailer. My own 192RBS is an older 2014 model that typically runs ~ 4600 lbs loaded and ready to camp but I'd imagine his newer 192RBS would weigh about the same. Although I have no idea what model year his Ridgeline is it seems to do the job for him. ๐
โFeb-28-2017 05:31 AM
โFeb-28-2017 04:42 AM
Bumpyroad wrote:camp-n-family wrote:
If you want a full size trailer (non pop up) then the only suitable Hondas would be the Ridgeline or Pilot.
back when I was deciding between a Pilot and My Highlander, the Pilot was only rated to tow a 3,500 lb. rv, or a 5,000 lb., boat.
bumpy
โFeb-28-2017 04:37 AM
swtrainer wrote:
My recommendation: Shop around and decide on a travel trailer. THEN, decide on a tow vehicle that can handle it adequately.
