Apr-06-2014 10:58 AM
Apr-24-2014 05:37 PM
Apr-24-2014 11:43 AM
mkirsch wrote:Sort of like a South Korean Ferry. When operated within reasonable situations and reasonable experienced persons, it won't tip over or push your steering in a corner? I wonder how many times that Ferry operated port to port without ever having issues with it being 66%-83% beyond it's recommended allowances?
To be fair, the ones running F-350 duallys @ 1000lbs over are a lot less overweight as a % of their payload capacity than a Tundra @ 1000lbs over.
A typical F-350 has 4000-6000lbs of payload capacity. Being 1000lbs overweight is 16-25% overloaded.
A typical Tundra has 1200-1500lbs of payload capacity. Being 1000lbs overweight is 66%-83% overloaded.
Just put the 1000lbs into each empty truck and tell me it's the same. The F-350 will squat a fraction of an inch. The Tundra will squat 3-4 inches.
Apr-24-2014 10:21 AM
Apr-24-2014 08:48 AM
Apr-24-2014 07:48 AM
Apr-23-2014 05:36 PM
Apr-23-2014 05:14 PM
Apr-23-2014 01:25 PM
Apr-23-2014 11:25 AM
Apr-23-2014 10:59 AM
Apr-07-2014 12:03 PM
kknowlton wrote:
Ouch, Maria. Fellow Tundra owner here; I don't think you're going to find one that has everything you want. Even that last one will probably put you over your truck's limits once you get your gear loaded & fill up with water. Tundras are great for towing, but the frame under the bed of the truck is a C-channel, lighter weight and less sturdy than the frame that's under the engine or even the cab. That helps the truck weigh less and get better mileage but doesn't serve well for a truck camper.
You may want to rethink your plans. Good luck!
Apr-06-2014 07:25 PM
Apr-06-2014 07:21 PM
Carb Cleaner wrote:
Here's an example CLICKY.
Camplite 5.7 Ultra Lightweight Aluminum Truck Camper. It's listed as 1,100 pounds dry weight. No water closet, but it gives you an idea of what's up.
Apr-06-2014 07:06 PM
