macminn
Jul 11, 2017Explorer
Newbie plumbing questions
We bought a used 2011 Keystone Passport travel trailer. Have it all cleaned up, getting it ready for the road. This forum has helped a lot! The previous owners had winterized with rv antifreeze. I Took the plug out to drain the water heater. Wanted to check the anode. Thought it was on the plug, but the plug is nylon, so obviously not. Is the anode under the pressure relief valve? Attempting to attach a picture, hope it works.
Second question. Trying to get the pink anti freeze out of the line near the water heater. The valve seems to be open. I assume it the valve is pointed up, or at 12 o'clock, that is to bypass the water heater, or is my thinking flawed. Again, hope the pictures worked. Last question. When filling the fresh water tank, when it got full, it leaked inside the fill valve. The valve looks a little rough. I didn't take a pic of the fill hole, but I assume when it got full, it would just back up. It did that, but also leaked inside the trailer.
