Newbie question about plugging in at the house
Imthebeachgirl
We are in the research mode to purchase our truck camper. But I have a question and hope some of you seasoned tc campers can give me info? With the correct adapters, how much can you run when you are hooked up to a house with 20 amp service. I am looking for how many items can you use? AC, micro, stuff like that? We are hoping on camping in family and friends driveways and yards and I just want to know what to expect. Thanks
13 REPLIES 13
Ozlander
Some older houses may have 15 amp fuses instead of 20 amp breakers.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
Imthebeachgirl
Thanks everyone for your replies. I love this forum where I know I can come with my "dump" questions, that you have probably heard over and over again, and get some good info. Have a good one! Laurie in Fl.
Kayteg1
My AC draws less than 7 amps when running, so only starting up require turning other stuff off.
Once AC is on, I can run microwave even on 15 amp circuit.
Reddog1
Buzzcut1 wrote:
I can run everthing when plugged into the side of my house
As do I. I use a 12 ga extension cord, about 20 to 30 feet, with typical 15 amp male and female ends. It has been working for over 15 years, at home and when visiting relatives. Gotta confess, I do not recall if I have ever ran the microwave and A/C at the same time. My A/C is a 9200 btu Polar Cub, which only uses about 9 amps as I recall.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Big_Rig1
We put in a 30 amp outlet, so no worries about what we can & can't run, we can run everything.
Big Rig (John)
04.5 Dodge Quad,3500,CTD,DRW,4X2,48RE, Ranchos, Tatman Wedgies
2015 Arctic Fox 990, 100W solar, power rear awning, Fox Landing, no generator, no oven
portscanner
Use everything BUT AC
-or-
Use only AC
If you use everything including the AC, you will spend a large amount of time resetting the breaker in the house.
Best bet is get a 30 amp outlet installed by an electrician.
One beautiful wife -Trooper and Doc the furcampers
2019 Dodge 4500 Flatbed with 2013 Chalet TS116 http://www.brittanynews.us
jimh406
It's better to add a 30 amp, but I ran everything before I put in the 30. There are some YouTube videos on how to. I paid an electrician because I was upgrading my service anyway.
2chiefsRus
CA Traveler wrote:
One heavy draw item at a time should be OK.
BUT Few homes actually have 20A plugs. Most likely they have a 20A circuit with multiple 15A plugs on that circuit. That means you have to share the power with whatever else is running in the house. That might be very little or it might be a significant draw.
So talk to the owner and see if you can identify a lightly loaded circuit to use and don't be surprised if you just get a blank stare.
Plus the length and size on your extension cord is a factor. The shorter and bigger the less voltage drop. Therefore buy a 10 ga 50' extension cord for under $100. Price is not a factor as you don't have CG fees.
x2 - we had a randomly occurring breaker flipping problem when plugged into a friend's garage outlet until we figured out that his freezer in the basement was on the same circuit.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
allygerry
We run everything when hooked up on 20 amp circuits, only one major item at a time.
CA_Traveler
2014 Grand Cherokee Overland
Bob
time2roll
20a should run any single large item or all the small stuff.
Large is A/C, Micro, electric water heater, hair dryer, Keurig etc.
Worse case the breaker will trip and you reduce the load.
TDWebster
If you are plugged into a 20 amp, 110v service. You can use everything but the a/c. You would also want to watch how much you had on at any given time, but it should run fine.
Buzzcut1
Nomad II
Nomad II
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
