RetroAirBnB's avatar
RetroAirBnB
Newbie trailer owner, question on water pressure pump
I bought a trailer for my side yard to create an AirBnB.
Everything is powered up and running. There's a panel on the wall where I can check battery charge level, and levels in the tank. At the bottom of that panel, there are two red lighted switches. One turns on the hot water heater (which sparks and fires up). The other turns on the pump for water pressure.
I ASSUME that the water pressure pump should ONLY be turned on when my renters actually need water pressure. Otherwise, if the pump is left on, it will burn out? Am I right in that?
