โDec-22-2022 09:27 AM
โDec-22-2022 06:00 PM
Cummins12V98 wrote:FishOnOne wrote:Likes to tow wrote:
I have a 2021 Ford F250 with the 7.3 gas engine and the 10 speed transmission. It was bought new and has 20k on the odometer. Supposedly there is no scheduled maintenance on the transmission! I've always changed transmission fluid in all my previous trucks at 30k miles but the dealer says this will not need it. There is no dipstick!
Also......... Is the 10 speed in my F250 7.3 gas the same as the 10 speed used in the F350 thru F550 with the 6.7 diesel engine????
Its the same transmission but has a different torque converter.
The owners manual states to change the oil every 150k miles but I would change it around 60k. As for the dealer I would never go back to that one again.
I have to ask if Ford states 150k why 60?
โDec-22-2022 04:35 PM
โDec-22-2022 01:37 PM
โDec-22-2022 12:21 PM
way2roll wrote:
It's the same transmission and you are correct there is no scheduled maintenance. That said, I've read that it's recommended you change the transmission fluid around 90k miles.
I have a 2020 F350 6.7 and the transmission is starting to concern me. Aside from shifting very hard in 2 and 3 (it's always done that), the other day it shifted out of drive. I started to pull out of my drive and it just disengaged for about 10 seconds, coasted and then only revved until it banged into gear eventually. Thank goodness I hadn't pulled out onto a busy road. I've also had issues in 4WD. I was towing in some sand a few weeks ago and I put it in 4WD. it started to work fine at first and then wouldn't take fuel at all. It just died when I hit the the throttle. Of course I've had these things investigated at the dealer and they can't ever seem to replicate the issue. We are downsizing to a smaller motorhome and frankly I'll be glad to be rid of the truck. It's nice when it's working but I cringe at potential issues on such an expensive truck. I sleep better knowing it's still covered under warranty but I really worry about long term issues with it. Been lots of reported issues with the new transmissions and in most cases Ford doesn't want to step up.
โDec-22-2022 12:09 PM
โDec-22-2022 10:24 AM
โDec-22-2022 09:49 AM
