fishingfanatic
Oct 29, 2013Explorer
Northern Breeze Fan cuts off in AF 990
I have a 2007 AF 990 with a reversible, variable speed Northern Breeze fan in the cabover. Sometimes you can turn it on at a medium speed and it will run a good while and cut off. I have Googled enough to see that there were problems with the NB fans control boards and they now only offer a single speed, 400cfm fan. Should I just replace the fan with another brand before it quits completely? Any suggestions that would work in the same hole and same wiring setup? Thanks in advance.
