OK stupid question
w8lpn
Ok here is my question. I just purchased a husky round bar WDH with sway control. I haven't really had a chance to read about it yet, but when you hook up the bars, do the chains have to be tight or have some give in them? I know this is kinda stupid, but I am just kinda curious. Thanks.
2014 Ford F150 5.0
1985 citation 30 ft camper
Husky WDH with sway control
11 REPLIES 11
w8lpn
thanks again i have been reading and also checked the manual I think I can figure it out now, thanks again.
2014 Ford F150 5.0
Passin_Thru
Lots of Youtube vids.
ken56
I have always been told that the bars should be reasonably parallel to the A-frame. Pay attention to the recommendation on how tight the snap latches need to be tightened onto the frame..hint...don't crank the bolts so tight it distorts the bracket. read up on how to properly set the hitch system up for your tow vehicle, again, check your trucks owners manual for this.
1stgenfarmboy
The only stupid question is the one you don't ask.
1993 Dodge W350 Cummins with all the goodies
2014 Ram 1500 Laramie Longhorn 2wd 395hp
2017 Forest River Surveyor 243 RBS
2001 Super Sherpa & 2012 DL650A go along also
drsteve
There is a sticky at the top of the Towing forum that tells you in detail how to set up your hitch.
https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/17730894.cfm
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
mogman
You need to read up on setting up a WDH and what is the reason for using a WDH.
It's not hard to do, a little basic measuring, a little fiddling with angling the ball mount (most likely) backwards, getting the truck fender measurments correct, having the trailer sitting level, not nose up or more than just slightly nose down, etc. Make sure to have adequate tongue weight, 12-15% of loaded trailer weight.
A few hours should have you in the ballpark, then after towing, perhaps a little adjusting or tweaking to get it as close as you can.
'15 Ford Transit 250, 3.5 ecoboost, 3:73 ls
'12 Lance 1685
w8lpn
yea im going to read the instructions just havent yet, just getting an idea. Thanks for the replies
2014 Ford F150 5.0
Lwiddis
Yes, enblethen, no question about using the manufacturer's website/instructions to set up a new system but OP says he will read the instructions. I viewed it as a preliminary question...chains need tension on them to transfer any weight.
enblethen
They need to be tight. How tight?
I would suggest going to the WDH nmanufactuer website and download how to set up there bars.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
w8lpn
Thanks for that. I have been towing without WDH and just got one. Not cool to tow without WDH. I'm kinda excited to be able to use this new hitch. I mainly have been towing to local campground 4 miles, but in a week Im going about 2 hours away.
2014 Ford F150 5.0
Lwiddis
NOT a stupid question! Tight after I get the block out from under the jack and the Tahoe has finished leveling itself. The chain tension is what transfers the weight back to the TT wheels and forward to the TV's front axel.
