LVJJJ's avatar
LVJJJ
Old brakes, Old trailer
I have a 1985 Wilderness 3000CL TT, it is in very good condition, aluminum siding still shines, upholstery perfect, everything looks and works good, except the brakes.
I think it spent most of it's life sitting at an RV park near the ocean here in Western Washington as there is a lot of surface rust on the undercarriage, nothing serious. It seems to have been towed so little that it may be that the brakes are the original as well as are the bearings. Bearings are good and the shoes only half gone and drums are still good.
The brake springs and mechanisms on each wheel were rusted and stuck and therefore didn't work very well. Wires going to each wheel were in pretty bad shape and some not even connected.
I cleaned the mechanism off with brake cleaner and a brush, lubed the star wheels and got them to work like they should. Had to replace one of the magnets. Also fixed all the wires going to the magnets.
I've never been totally happy with the trailer brakes as they don't grab as much as they should. No way will they lock up. I can use the manual control (Prodigy) to slow things down but it takes a lot of pressure on the brake pedal to get everything stopped. I know that the manual control isn't supposed to be used to stop the whole rig, but on other TT's I've had, the manual control had a lot more effect. I like to manually engage the TT brakes first since the old van brakes aren't the best, but if I have to, a lot of foot pressure will bring everything to a pretty quick stop.
A couple of times on our last trip last week, the Prodigy briefly showed the trouble code "n.c." so the trailer brakes stopped working for a few seconds.
I should note that the tow vehicle is a 1965 Chevy Van with a 292 I6 engine. Been towing with it since 1988 and about a half dozen different trailers.. The trailer wiring from the Prodigy back is all new. When the brakes are applied the brake terminal (blue) registers 12v.
Today I jacked up the TT, hooked it up to the TV, took off all the wheels and gently applied the van brakes. All of the magnets were buzzing. When I rotated the right side brake drums there was some resistance and could hear the magnets contact the drums. However, on the left side, the wheel with the new magnet actually locked up and the rear wheel spun with no resistance or magnet contact (but the magnet was still buzzing). What's weird is that the trailer has always slowed down in a straight line and the brakes have never locked up.
The lever the magnet is connected to is real tight on the rear left side wheel, but the lever on the front one with the new magnet has a half inch of play before it begins expanding the shoes.
I've always done most brake and bearing work myself, but this one stumps me. Any ideas?
