shasta24's avatar
shasta24
Overdrive or not?
I finally purchased my first three quarter ton suburban with 8.1 motor. Until now I had a half ton with 350. I always towed in third gear because I understood that towing in overdrive was a no no. Now with this huge motor and trans. does this rule still apply? It has 4.10 gears with the tow haul mode button. Should I use that button when towing and pull shifter down to 3rd? Thanks for your help. Also my trailer is a 79 Shasta that dry weight is 5250 pounds.
