iwon415
Apr 02, 2014Explorer
pass through window leak
So I had a leak from the pass through window. Checked for plugged weep hole (doubtful in new camper) but that wasn't it.
Sealed the window in plastic, went driving in rain. No leak. Must be it.
Nope, checked it again and it leaked onto the towel I had covering the step to the overhead cab which is at bottom of the window.
Changed the towel and parked it in driveway which is sloped. No leak.
Today I had it sitting at my mothers in flat parking lot, towel is soaked again.
Apparently it only leaks when parked flat, not on slope, and doesnt leak while driving. Which should mean leak is on roof and it is running down inside the wall and coming out the lowest point which is the window frame bottom. Anyone encounter this and what would be the likely culprit on the roof? Will I probably have to seal everything on roof from midway point forward?
