โJul-16-2014 07:03 PM
โAug-26-2014 10:01 AM
โJul-17-2014 08:12 PM
Lynnmor wrote:Sheps wrote:Lynnmor wrote:
If the outlet is on the side of the tank that is the problem. The pump will suck air when the water drops to the top of the fitting. Maybe you can tee into the tank drain.
The outlet is on the side at the very upper front road side corner of the tank. That seem like it would require a pickup tube inside the tank that extends to the bottom of the tank.
I like the idea of teeing off of the drain. Just a few fittings and some hose and a plug for the top fitting. I would have to route the hose back up through the floor to the pump. Mabe run hard pipe to above the frame or the floor, then change to the hose. I guess for protection, then seal the new floor entry.
Do you think the pump will pull water this extra distance? It's a Surflo pump I believe.
There is no problem with the pump pulling it. I do think that the pipe at the top is just a vent, don't know. Can you trace that line and see where it goes?
โJul-17-2014 09:40 AM
โJul-17-2014 09:07 AM
โJul-17-2014 08:55 AM
โJul-17-2014 08:24 AM
โJul-17-2014 08:08 AM
Boband4 wrote:
Is it possible that the pickup has a hose in the tank and the end has curled so it is a few inches above the bottom of the tank?
โJul-17-2014 05:47 AM
โJul-16-2014 07:51 PM
โJul-16-2014 07:22 PM
โJul-16-2014 07:15 PM
