al7601's avatar
al7601
Pitch on slide outs?
So trailer is perfectly level side to side but each slide out is very slightly pitched towards the trailer. Is this normal? One slide on each side
  • Community Alumni's avatar
    Community Alumni
    I've had three different rv's and they were all built with a slight slope on the slideout roof to the outside, not towards the trailer.
  • is the floor of the slide actually pitched, or just the outside wall? On our MH, and a few others I have seen, the inside edge of the floor rises a bit when the slide comes in. The outside wall has to be pitched a bit to seal when the slide is fully retracted. When extending the slide, you can watch the lower edge pitch out as the floor of the slide settles in place.
