โJun-12-2015 09:52 AM
โJun-13-2015 08:34 AM
jaycocreek wrote:
The inverter IS not the noisy handi.My sons friend has a handi 3k and it's just flat out noisy compared to either the 2 or 3K Honda inverters,almost as loud as my 4K Generac.
โJun-13-2015 08:33 AM
โJun-13-2015 07:11 AM
โJun-13-2015 06:39 AM
โJun-13-2015 02:44 AM
I'd also assume that running one 2K (if not needing air) would be a lot quieter than the 3K.
โJun-12-2015 09:32 PM
Rainier wrote:Wise sales says 44 lbs. That would be a weight difference between the 3K and the 2 X 2K sets of 61 lbs. I'd also assume that running one 2K (if not needing air) would be a lot quieter than the 3K.DarbyWalters wrote:
Been looking at the Yamaha EF3000iSEB with boost technology. With a 50amp to 30 amp plug...I think it could run the AC/lights/micro/TV...fridge and water heater could run off propane.
From ad: The 3000 Watt EF3000iSEB weighs 149.9 pounds and starts with ease with its electric starter. Designed to be acoustically sound, this extremely quiet generator (53-60 dBA) features Smart Throttle which allows greater fuel efficiency and noise reduction. It will run up to 19 hours at ยผ rated load on a tank of gas. With features such as Built-In Wheels, Boost Technology, and an Oil Watch Warning System, the EF3000iSEB is a powerful yet portable medium-range inverter!
Worried about this: Rated AC Current / Maximum 23.3 / 25 amps @ 120V
For about the same price you can buy two yamaha 2000 inverter generators and then connect them together for 4000watts to run AC, Etc. They also only weigh 47 pounds. That's the set up I have and I love it.
โJun-12-2015 08:34 PM
โJun-12-2015 07:41 PM
โJun-12-2015 02:24 PM
โJun-12-2015 12:44 PM
โJun-12-2015 12:17 PM
โJun-12-2015 12:10 PM
โJun-12-2015 11:36 AM
โJun-12-2015 11:18 AM
