mrgreetis's avatar
mrgreetis
Position of propane regulator - facing forward or back
I have a Keystone Springdale and I had cause to remove my propane cylinders for refill and when I reinstalled them, I thought I had maybe positioned the regulator backwards. It looked like the regulator was mounted facing toward the TT with the sightglass only viewable from between the front wall and the cylinders. So I would have to somehow fit my head into that space, turn sideways and then could see if it was red or green.
I switched it around so I could see it from the front and I am thinking of putting a piece of plexiglass or something similar across a hole in the tank cover to be able to see without pulling the cover. I did find this thread –
Link
Is there a reason for the regulator facing and did I goof by changing the position? Any opinions on either the position or the window?
Thanks, Mike
