Kayteg1 wrote:
Whole idea of having inverter is so you can have 120V without running generator.
Or to put that a different way......IF you are plugged into shore power OR have the generator running.....there is NO need for an inverter.
IF you have mostly the stock configuration that came with the RV, there is little need for an inverter.....because you probably will need to run the generator a couple of times a day for a couple of hours just to recharge the batteries. With just a small amount of planning ahead, you can also charge your phones, cook breakfast, cool down the beadrooms for night time, etc. at the same time.
It's pretty obvious that he doesn't understand what he is dealing with......but we've all been there at one time, to some degree.
