Old-Biscuit wrote:
Fifthly.......
Shooting a full propane cylinder with a firearm will cause a Hole in cylinder and allow propane to spew out. But it will NOT cause it to explode or a big flash etc.
Must have a source of 'ignition' to light off the propane VAPOR
MythBusters episode 95. Look it up.
Nice pictures OLD Biscuit.
First hand experience:
Full 100# (23.5 gallon) LGP tank standing upright with a burning road flare tapped to the back side about 4" lower than shoulder of tank.
From a 100 yard resting position I fired a 30-06 180 grain Hornady Spire pointed bullet at a marked spot 2" below the shoulder on the front side of tank.
Impact of the bullet put a 30 caliber sized hole in the front and a slightly larger hole in the rear of the tank exactly on the marked spot 2" below the shoulder.  This was a direct line of sight through the vapor area inside the tank.
The impact of the bullet also caused the tank to fall over backward.  Before the tank hit the ground the LPG vapor coming out of the hole in the back of the tank, which was under pressure, caught on fire.  Immediately after, the LPG vapor coming out of the front hole, also under pressure, caught on fire.
The tank finished the backwards fall to the ground and began spinning in complete circles until all the LPG (liquid, because the tank was laying horizontal) had stopped flowing from the tank and burning.
I shot at this tank on a plowed field road in a very secluded area.   There was 5' high frozen snow banks on the road I had plowed across my field. The banks were blackened by the smoky fire.
I had expected the tank to explode after I shot it.  It did no such thing.  It just vigorously burnt until all the pressurized LPG was consumed by the fire.
Lakeside
