Mcamper's avatar
Mcamper
Proper tire pressure?
I have always run the tire pressure on my travel trailer according to what the tire indicates. My specific tire states a load in pounds (I think it is 1750) and then a tire pressure of 50psi. I keep the tires at 50 psi. I am running the standard ST tire.
A friend of mine says that he runs a pressure that “feels right” and that may not be the maximum pressure for the tire. He also said he runs 75 to 80 mph (on the interstate) and does not pay the 65 mph rating on the ST tire any mind. I have always tried to stay around 65 mph or less, because I always have been told a higher speed for more than just a minute or two could do permanent damage to the ST tires. I think the max pressure for his tires is around 90psi, and he is running something around 75 or so.
I am hoping for some opinions on this. Am I being too particular with my tires?
  • I thought this sounded dangerous to me, especially traveling at 75 to 80 mph pulling a trailer. I have been on trips where I use the interstates, but I hold my speed to no more than 65 even in the areas where the speed limit is 70. It makes sense to be because it feels a lot safer, and I think it saves the trailer tires too.
    Thanks for the responses to my post!
  • Then you first have to calculate what the minimum pressure is for the loads on the tires.
    If your tires are overrated, wich I think they are not, you can use lower pressure.
    If the tires are yust enaugh , you are even allowed to go 10psi over that 50 psi, because its not the maximum pressure of the tire.
    If your friend lowers the presssure until it feels good, he probably lowers under the border at wich the tires are save.
    Gripp and comfort get even better if your pressure is below the damage border, but at a sertain moment you get an accident by blowing tire.
    So give the GAWR's and GVWR of the trailer and number of tires that load is resting on, and the maximum load and pressure-rating ( Probably C-load/6ply because of the AT pressure of 50 psi) , and I will calculate with spreadsheet i made , a pressure with some reserve for little overloading and unequal loading R/L.
    It is always better to weigh the vehicle, but if you havent , we have to do with the GAWR's and GVWR( gross vehicle weight rating).
  • Ditto on the wrong. Your friend is a disaster waiting to happen. Stopping a TT on a dime is a tough job at 60ish, but 75 - 80? Forget it. Use the recommended tire pressure and check it frequently....when cold. And have a light foot. You'll also be happier at the gas pump.
  • Let us know your friends schedule so we can stay out of his way!
  • I run the max air p on what ever RV I have. At the present time 60. Seldom drive over 62 MPH.Your friend is wrong !!
  • 75 to 80 MPH with a trailer is suicide. Sorry, but you're doing the right thing. As far as pressures, A load pressure chart will work. Mine are Max 50, but I am no where near the Max Load, so I run 45, which is still more than enough for the load based on the chart.
    No you are not...and your "friend" should by MORE particular with his (and his speed).
