Feb-02-2015 05:49 PM
Feb-04-2015 04:57 PM
Feb-04-2015 04:28 PM
Feb-04-2015 03:08 PM
Feb-03-2015 07:06 PM
Feb-03-2015 06:28 PM
Feb-03-2015 06:04 PM
Feb-03-2015 10:13 AM
Feb-03-2015 09:54 AM
Feb-03-2015 09:37 AM
Feb-03-2015 08:32 AM
BenK wrote:
Rebed them...
Here is a good thread about curing new friction materials...or do a
search using: brake, bedding in
Most all say about the same thing, though there is a slight difference
on HOW2 between regular vs performance vs race
Brake Pads page4BenK wrote:
Don...didn't want to say it before, but now that you've indicated that
you have glycol 5.1...it is a very good thing.
ABS modules cost in the thousands of bucks and they have the same seal
problems with silicone as normal OEM braking systems
As for the other poster who said new pads had the warped rotor feel...it
most likely is NOT warped rotors but a need to cure and bed in the new
friction materials (pads)
All friction materials need curing and when on vehicle brakes..the term
is bedding in.
The softer materials need more curing than harder materials
What is most likely in your case is that you stopped moving when the
friction material was still curing. Hot and outgassing to create a
high spot on the rotor surface.
Only takes a few ten thousandths of an inch to be noticeable on the
brake pedal
Do a search here and/or on the internet using: "brake bedding in" and
you will find many methods. Most are generic, but there are differences
between mud hen freebies that come with rebuilt calipers all the way
up to pure track/race pads.
This is one of the better explanations and is also my opinion on the
matter. I also bed in my brakes differently, but won't list it here
and best to use these folks. Hot link below
Pad and Rotor Bed-In Theory, Definitions and Procedures
StopTech's Recommended Procedure for Beddin...
This is also a good one:
Zeckhausen Racing
Feb-03-2015 07:24 AM
Feb-03-2015 07:10 AM
Feb-03-2015 06:38 AM
jbres wrote:
terryallan- how do you have them turned? Would it be cheaper to just buy new?
Feb-03-2015 05:05 AM
