path1 wrote:
Tequila wrote:
BTW I told the manufacturer of my trailer about the push button mod, they thought it a great idea and have forwarded the suggestion to their design team.
Good mod and I hope Northwood incorporates your idea into all there products.
In wives Arctic Fox (Northwood also) we had a problem with a hose clamp coming loose and hose popped off and water made a mess. I don't know if your TT is different than ours but our water pump is just below the floor surface. Sort of tucked along side water tank just under floor surface. We would not any water get inside trailer (only underneath)if there was some type of shield or deflector over pump and connections. So after getting all wet insulation out I got a piece of vinyl (old vinyl car floor mat actually) and put over top of pump and hose connections. Also I now check tightness of hose clamps twice a year. There is still room for air circulation if those pumps need it? I think it a good idea but still not 100% sure because it so simple I wonder why Northwoods didn't slap something over pump when building it?
I have also put a small line with a felt tip marker on at faucets connections underneath. That way I can tell with a quick look with a flashlight if they are wiggling loose and hopefully before water show up.
Good thing you were not on city water when you sprung a leak?
Once again great mod.
My pump is at floor level under the kitchen sink. Nearly all my plumbing converges on that point over a hole int he floor, which is where I think my largest risk is. For that reason I have a sensor sitting in the insulation in that hole. I gave the idea to Dave Mann and he seemed hyped about it. Very simple & cheap at the manufacturing level and would save a lot of roadside disasters. I also pointed out that the faucets they are using, are an accident waiting to happen, they look stylish, but not good for an RV. I have also seen the tap in my outdoors kitchen vibrate to the on position. For that reason I never leave the plug in the sink. Since I lead RV tours down into Mexico, I drive about 8000 miles a year down there. Mexico has over a million Topes (Speed bumps) and I am the first to hit them obviously, sometimes pretty hard. My chances of having a tap open by itself is considerably higher than most. It has happened on several occasions, but in each case no pump was on. Oddly enough the time I did leave it on, I was in the US, so it can happen anywhere. Maybe not so odd because when I have a group, reminding them about their pump is a departure routine. On my own, I am sloppier.
On wet insulation, the RV tech who did my repairs told me that slicing open the underside and pulling it all out was a smart move. Nearly all the repair costs were related to replacing the underside panels. On mine they were cloth like, Easy to slice open, hard to replace. They used that corrugated board instead.
