TxTiger's avatar
TxTiger
Question about GVW Rating on Door
I've been diligently trying to determine what weight TC I can put on my truck and still be within my GVW. I know many are over GVW and have had no problems, and ultimately I may also be over GVW but would like input.
I have a 2000 F250, cc, sb, psd, 4x4. My door sticker says GVWR is 8,800 lbs and rear axle GAWR is 6,084 lbs. An F350 of the same year has a GVWR of 9,900 lbs and rear axle GAWR of 6,830. Reading lots of stuff on the differences, it comes down to the following:
1) the F250 had 235/85/16 E tires, rated at 3,042 lbs each, the F350 came with 265/75/16 E rated at 3,415 lbs.
2) the F350 had rear overload spring vrs none on the F250
3) the F350 had rear sway bar vrs none on the F250
4) the F350 had 4" blocks between the axle and rear leafs vrs 2" on the F250
5) the F350 had heavier front coil springs.
All of the above gave the F350 1,100 lbs more of GVWR and 746 lbs more rear GAWR.
My truck is optioned with the factory Heavy Service Suspension Package/Camper Option which includes everything listed above for the F350. So I know my trucks ability is that of 9,700 GVWR and 6,830 rear GAWR. Yet my door sticker shows the GVWR and GAWR as if it had none of these options. Does anyone know if this is typical for the manufacturer to keep a standard door sticker even your truck came from the factory with options that increase the GWR numbers?
If I have it figured correctly, with 9,900 GVWR and unloaded but fueled weight of 7,200, leaves me 2,700 lbs to stay within my limits. If I use the 8,800 GVWR it puts me down 1,100 and limits me to not much more than a camper shell.
I guess my question is about the door sticker not reflecting the options. I'm pretty sure that's the way it came from the factory and these options were not added later. Does anyone know if it is typical for the door sticker not to reflect options that change the weight ratings? Thanks for any input.
