Crambo
Oct 30, 2015Explorer
Question about steel wheels
I am planning on putting maxxis 8008 load range D tires on my camper and someone on the forest river forums suggested I make sure the rims can handle 65 psi. I looked on the back of the rim and all it showed was a max load rating. I called Lions head which is the rim manufacturer and the lady said the rim did not have a PSI rsting, only the tire and valve stem. I'm assuming I'll be ok as long as I don't exceed the weight rating of the wheels. Am I correct?
