Butch50
Mar 25, 2014Explorer
Question for the trailer towers here
I have 2 trailers that I'll be towing at different times behind my truck camper. I just added the an extension cable that you insert by taking apart the connection at the back of the plug and inserting this cable between the cable and the 7 pin connector. So while I was doing this I backed it up to my Aluma 10' flatbed trailer to make sure it was going to work before taking a hole saw to the bed of the truck. All worked but I have a strange situation. When I have the key turned on to try out the turn signals I was getting a click about every 10 seconds from the brake on the passenger side of the trailer. So I turned off the turn signals and the ticking was still there. I'm sure it is my brake magnet clicking but I have never seen/heard anything like this before.
As long as I had power turned on in the truck the ticking continued, when I turned the power off the ticking stopped. Now the Ram is different than my Ford was as there is power being fed to the 7 pin plug as long as it remains plugged in.
I was going to check out the wiring but it has been to cold to start crawling under the trailer to see what I can find.
Any suggestions of what might be happening or causing this?
