Ram 1500 3.55?
tbolt2000
I have been looking at Ram 1500 4 door. Looking at years 2011 to 2013, Most likely 2012. Gear ratio 3.55. Thought need the 3.92 gear, now not sure (see below). I don't ever plan towing greater than 6500#. Looking for a Ram towing of 10,800#.
Would a Ram with tow capacity of 10,800# be over kill or would 8800# be good choice?
Things I have noticed in looking up the VIN's for Ram's interested in, for the ""Equipment Listing"for a specific Ram it will show a gear ratio as 3.55.
If I plug the VIN here for 'LOOK UP MY VEHICLE it will either show the towing for a 3.55 as either 10,800# or 8,800# based on the VIN I plug in.
Why is it a 3.55 gear can tow 10,000#'s or 8,800#'s?
How do I really know what RAM I'm looking at can tow?
I have read also that 2013 and 2014 Dodge stated on sticker that it had a 3.55 gear when in fact it had the 3.21gear on some RAM's it sold.
I've done so much with so little for so long, I'm now qualified to do anything with nothing.
20 REPLIES 20
FLY_4_FUN
Dodge has online tables that will list all of the possible variables others have listed above...and give you the max ratings. Even 20" tires vs 17 can impact your ratings. On a personal note I had a 2004 4x2 quad cab with a hemi and 3:55 gearing and I regret not having a more "towing friendly" gear in there. As mentioned before, having too much truck is rarely an issue so the 3:92 gears will perform slightly better than the 3:55 with all other factors being the same. The only downside is worse mileage, but that's a compromise we face with towing houses down the road.
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
mkirsch
Nomad II
Nomad II
The tow rating of a truck depends on engine, transmission, axle ratio, cab/bed configuration, and whether it's 4x4 or 4x2.
Larger cab/bed configurations and 4x4 add weight which reduces towing capacity.
More powerful engines, more gears in the transmission, and lower (numerically higher) axle ratios raise towing capacity.
So if two trucks have 3.55 axle ratios, and one is rated to tow 8800 and the other is rated to tow 10000, that means something else is different. 6-speed vs. 4-speed transmission maybe? Higher output Hemi? Regular cab 4x2 vs. crew cab 4x4?
The owner's manual will give you the tow ratings. All you need to do is find the towing section and look up the truck's cab/bed/drive/axle ratio combination in the tables.
MNGeeks61
I googled this before -
Pretty much only the 3.92 gears in a 4x2 if you're talking quad/crew. Yes, a couple of 4x4's will do 10k, mostly the standard cabs. But not 3.55's. The 2012's seem to tow the most (on avg)
2013
2012
2011
ChooChooMan74
I don't believe you will find a Ram 1500 with 10k towing capacity. Maybe a stripped down 2WD regular cab with 3.92.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
KD4UPL
When it comes to towing there's no such thing as overkill.
The tow rating of a vehicle is based on much more than just axle ration: engine, transmission, wheel and tire combination, cab and bed configuration, various coolers and other parts all figure in.
While a 3.55 geared truck would tow that trailer a truck with 3.92 will do it better.
Golden_HVAC
2.21 gearing is really an oddball rear axle ratio. Even 3.21 would be rare in trucks set up for towing.
3.55 or 3.92 would tow about the same - performance wise. Just the 3.92 would turn a few more RPM at a given road speed and therefor be able to make a little more HP at that higher RPM. However even with the lower gearing, it will just downshift if you need more horsepower and will change the RPM all the way up to 4000 if needed to make plenty of power to get over a mountain or onto a freeway.
Have fun camping!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
