Cummins12V98
May 17, 2016Explorer III
Perrysburg Dodgeboy wrote:
You guys running DRW had better be careful about how much you deflate your rear tires! Even unloaded the tires can rub on the inside going over bumps or hauling even minimal loads in the box. This will over heat the tires and can cause a blow out.
Don
At 35psi on my Dually rear tires there is no contact or even close. It's all about the load placed with the proper inflation.
