Aug-26-2021 02:22 PM
Sep-08-2021 04:39 PM
ShinerBock wrote:
Ram's 4wd system disengages the front axle completely when not in use unlike the Ford system which keeps the front axle spinning at all times, but locks the hubs when power to the wheels is needed.
Sep-08-2021 03:44 PM
mudfuel07 wrote:
My LB SRW 3500 does this in 4wd. It hops like crazy when I try to turn, don't notice it in 2wd. Don't know if it does in on pavement or not, never tried 4wd there. Taken it to the dealer a couple of times and they said it's normal. My SB never did it.
Sep-08-2021 12:31 PM
Sep-08-2021 12:07 PM
IdaD wrote:cummins2014 wrote:4x4ord wrote:ShinerBock wrote:4x4ord wrote:
Are you sure it is coming out of 4wd? Jack up one front wheel and see if it spins freely. Should Ram front hubs free wheel when in 2wd? (ie Does Ram use a auto lock hub like Ford or a constant locked hub like GM?)
The Ford transfer case does not transmit power in 2wd but the hubs Auto unlock as well. So with the Ford you can manually lock the hubs but you are still in 2wd until you shift the transfer case to 4 hi or 4 low. Chevy does not have hubs that disengage … the front axle and diff rotate in 2 wheel as well as 4 wheel drive? I think Ram is like Chevy but I don’t know?
I can't manually lock my hubs on my Ram ,but they are automatic locking , but no I don't believe they stay locked on my Ram . Nor do I believe my front driveline turns in 2hi. My old Superduty had automatic locking hubs , as well as manual. I suppose there is some need for manual hubs that are also automatic, but I never used the feature .
Auto hubs are great , I remember the days when we had to get out of the truck ,and lock the hubs, don't miss that. Many times not thinking we would need four wheel drive ,and needing it, and having to get out , and lock the hubs, wasn't terrible unless like the time I went thru some water on a mountain road ,and found my self stuck in a foot of water , you guessed it , I got wet getting out to to lock the hubs 🙂 If I knew as I started out on a hunt or whatever I would lock the hubs so I would be ready, now that's a thing of the past. We can shift into 4 wheel drive at any point now, so not sure what's the point of manual hubs ?? I am sure I will get enlightened on the need. 🙂
The hubs are always locked, but there's a center axle disconnect so your front driveline doesn't spin in 2wd. I prefer the old style manual hubs so none of the front driveline components spin in 2wd. It never took too much effort to plan ahead and not have to get out in the mud to lock the hubs.
Sep-08-2021 11:01 AM
TxGearhead wrote:
You have a point. Manual says 75w-90. Guess I will go with that and see if it helps.
Thanks for your input.
Sep-08-2021 10:53 AM
Sep-08-2021 09:37 AM
Sep-08-2021 09:19 AM
Sep-08-2021 08:58 AM
Sep-08-2021 08:56 AM
Cummins12V98 wrote:
For my DRW my frame and axle guy said OE spec of 1/4” toe is WAYYYYY too much. Set to 1/64” toe and all your outer edge “stepping” woes will go away.
Rotate front tires ONLY by moving tires side to side leaving rotation the same. Tires need to be separated from rims to do so.
Sep-08-2021 05:57 AM
Sep-08-2021 05:40 AM
Sep-08-2021 05:24 AM
Sep-08-2021 04:44 AM
Aug-29-2021 10:45 PM
TxGearhead wrote:
I bought 5 quarts of Valvoline full synthetic 75w-140 gear oil. Will let the dealer change it when I'm there next week for a oil change.
