Rear axle loaded weight Poll
Oregun
Recently I upgraded to 19.5 wheels/tires and have been thinking it's time to upgrade my old (1986)camper. So wondering how much weight others feel they can safely carry on their rigs rear axle for comparison purposes for those who wish to share.
Here is the Poll question: How much weight are you carrying on rear axle of your truck fully loaded with camper, water, gas, propane & any tows? Specify your configuration with the weight.
Here is my answer in bold to the poll with my current truck/tires, no tow for me.
99 F350 V10 SRW 2WD 245/70/19.5F, rear axle weight: 6980 lbs
57 REPLIES 57
hotrodfords
ticki2 wrote:
hotrodfords wrote:
Those are pretty low weights . What does the truck weigh empty ? Lance lists the DRY weight of the 835 at 2040# . Loaded should be close to 3000# .
I've looked around for my empties scale and I haven't found it but will post if I do. However, I remember the Camper weighed 2250 lbs before I put the a/c on it. The above weight ticket was before the a/c was put on it.
You won't find a lighter 3/4 ton truck. It's a work truck, rubber floor mats, no power windows or locks, or "fluff". Single CD player, single cab, single tank, single rear wheels, single cab ๐Ÿ™‚ It does have a/c and cruise control, optional aluminum wheels. But it's a stripper. An I love it that way.
Bedlam
Moderator
Moderator
My 2005 F250 diesel extended cab short bed weighed 4500 lbs on the front and 2750 lbs on the rear when empty. I know diesels can be heavy, but that is a light gasoline truck.
ticki2
hotrodfords wrote:
Here's the proof for my 2006 Chev 2500HD, single cab, 6.0L, auto. I love my Lance Lite 835 and my Chev truck. As you can see I still have 1604#s to go on the rear axle, though my tires are done at just over 6,000 total on the rear. I still have 1280# to go for GVWR:
'68 Avion C-11
'02 GMC DRW D/A flatbed
blueglide
8860 loaded with camper..wife..dogs..and stuff
Drive axle rated at 9650 with stock 17" tires
2017 Ford F450 XLT CC 6.7 4X4 Dually
2017 Arctic Fox 32-5m Fifth Wheel
ticki2
With the big increases in GVWR in recent years it would be helpful to know the tare weights also . I suspect the gain in cargo capacity is not as great as the increase in GVWR would indicate .
02 GMC , cab/chassis , dumping alum flatbed , extra fluids , some tools , 20' chain , 2 people + dog , 50 gals fuel . GVWR = 12000 , front = 4800 , rear = 8600
front = 4320
rear = 3960
total = 8280
With camper loaded for bear .
front = 4400
rear = 7220
total = 11620
'68 Avion C-11
Farmerjon
This is with the wife and I, 1/2 tank of fuel but missing 2 dogs 150 lbs, no food water or drinks and no trailer (600lbs TW)
and it was with our 2000 f350 7.3 Sc 4x4 DRW rated for GVWR 11,200, front GAWR 5200 and rear GAWR 8250
total 11060
front 4900
rear 6160
So loaded we were over our GVWR by about 1000lbs but under our axle and tire ratings.
With our 2015 F350 DRW we won't be anywhere near our ratings, 14000 GVWR , front GAWR 5940 and rear GAWR 9650. We will be weighing it next week trailer and all.
edited F530 to F350
2015 F350 Lariat CC LB 4x4 DRW 6.7, 6sp auto, 3.73
2000 F350 lariat SC LB 4x4 DRW 7.3, 6sp manual 3.73
1987 F250 Lariat SC/LB 4x4 SRW 460 4sp stick 4.10
1995 Jeep wrangler
99 Star Craft 953
hotrodfords
Bedlam wrote:
My rear is heavier than that empty:
Men are always less sensitive about those things than women and I applaud you sir for your honesty.
Oregun
Saw this truck on Portland Craigslist, I think he needs a few mods. ๐Ÿ™‚
Bedlam
Moderator
Moderator
This is my GVW:
And this is my GCW with trailer when traveling light:
jimh406
It's nice to be light! My rig is not!
hotrodfords
Oregun
sky_free wrote:
Oregun wrote:
sky_free wrote:
Fully loaded with 2 people, 2 dogs, and full water tank, truck and TC in sig:
Your post got me thinking. I could probably carry your AF 990 with less than 8000 on my rear axle. My truck is a super cab not a club cab, I have 2wd instead of 4wd and I have SRW instead of duals. So I should weigh less at the scale on the rear axle. Plus I don't have dogs anymore. ๐Ÿ™‚
Do you carry a lot of heavy options on your AF?
My wife really likes the AF campers.
It has the usual heavy options: A/C and Generator.
Let's say you save a couple hundred pounds, that's still 7,800 +-, or 3,900 lbs per wheel which is clearly 19.5 wheel territory if you want to stay under the max load rating on the tires. I wouldn't hesitate to throw on 19.5's if that is the TC your wife likes though :). We love it and it's probably the only TC we will ever own.
Yeah I have 19.5's 4950 per tire
sky_free
2017 Escape 17B, 2012 VW Touareg
JoeChiOhki
zcookiemonstar wrote:
This would be more helpful if every one included axle rating and GVWR.
GVWR is erroneous on my part these days, I've been erector setting my truck, its got bits from a number of different Dodges strapped onto it, now.
Rear axle I believe was rated for somewhere around 9000-10000lbs, can't remember what the front axle is rated for, but it usually has 3200lbs on it without the front basket loaded.
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
