Recommended jack stand ground support plates.
mt-ed
I'm not sure if I searched for the wrong subject, but I wasn't able to find anything there.
I would like to know what, if anything, others have found to work as good weight distribution devices you use when supporting your campers on soft ground with the jack stands, to keep them from sinking in?
Thanks again in advance!
17 REPLIES 17
deltabravo
Squares of plywood
Grit_dog
Navigator
Navigator
Lumber, plywood, those plastic leveling blocks, um that about covers it.
jimh406
I use about foot stall mat squares, but also squares of plywood work as well.
