atrerice's avatar
atrerice
Reese Sway Control Bar
Finishing up the first season with our TT and decided to get a friction sway control bar for our next trip. We have the Reese style hitch head with trunion style springbars. The hitch head already had the little sway control ball installed as well as on the TT. My question is about dialing in the amount of friction. How much friction should there be? Out of the box, it's tightened enough to where I can't slide the bar in or out at all. If I loosen the "On Off" lever, pull the bar out and tighten the lever back, if I put all my weight on it, it will barely slide back in. We towed the TT about 1,000 miles this year without much sway at all. Just wanted to add the swaybar for additional safety. Any suggestions would be greatly appreciated!
Thanks in advance!
