I replaced my Suburban cook-top with a 24" Smeg residential cook-top. The install was fairly straight-forward. I had to enlarge the opening and I had to fill the cut-out in the front of the counter. I built a drawer to fill in the front.
You will have to make sure that the cabinet is wide enough to accommodate the cook-top you intend on installing.
One thing to keep in mind is that a residential unit needs 120vac for the igniter.
![](http://i1095.photobucket.com/albums/i468/tomzpix/Cooktop%20install/5-AllDone.jpg)
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
