rcp123's avatar
rcp123
Replacing Flooring
We had a small bit of water damage from a leaking kitchen facet.
To make the DW happy, I am replacing the entire floor. We are using a laminate "click" flooring.
My question is: Should we glue the entire floor down, or leave it unglued?
Our thoughts are that with travel, an unglued floor may pop up.
Any advice?
Ryan
  • Ha ha you should be fine in August. I was meaning Octoberish time frame then starting in late Feb early March. Camp grounds ard pretty empty then :-)
  • Gosh! I was coming to CO in August but if it gets cold, no deal. Anyway, I have linoleum, Armstrong, glued down.
  • I agree with Steve, I replaced my floor with the wooden laminate floor and mine is floating and none of mine has come apart and I did the flooring throught out my 21 ft trailer. I did put a sheet of plastic down to help keep out some cold when it starts getting cold here in Colorado.
    Jim
  • I have installed lots of these types of laminate in my house.
    Normally the "click together" laminate floors are not supposed to be glued down when installed in a house. This is so expansion and contraction moves the whole floor as one unit and doesn't open gaps between the sections.
    I would guess you would have the same expansion/contraction issue in a TT, probably even more so due to greater swings in temperature.
    I doubt the floor would come up as the design of the snap edges make it very difficult to bend the joint upward. Personally, I would not glue it down.
    Steve
