crcr's avatar
crcr
Resealing the Edge of the Roof, Dicor, Eternabond, or Both?
I'm about to do some re-sealing to the roof edges on our travel trailer, to ensure no water damage. Attached find two images of the edge of the roof. I have a tube of Dicor Non-Leveling, Non-Sag Lap Sealant, which I have had very good luck with in the past. The TT is a 2011 model if that matters.
Where the roof material comes over the edge of the roof, you can see in some places there is cracking and slight separation of old caulk. I would like to cut and remove the separated caulk before re-caulking, but I am very concerned that it will be hard to do that without scoring or cutting the roofing material underneath.
So do you think I should just run a bead of my Dicor along there to cover and refresh the old caulk? Or should I instead overlap the edge with some Eternabond tape? Or, should I perhaps refresh the caulk AND then once cured, apply Eternabond over the edge?
Looking for any suggestions or advice with this project. Thanks in advance!
upload pictures internet
