deltabravo
Sep 03, 2016Nomad
turbojimmy wrote:
The only way to do it right is to remove the A/C unit, and if you're going to do that you may as well replace the $20 gasket. If you try to caulk around it you'll just make a mess (BTDT).
But if you insist, I'd use an interior/exterior type door & window caulk. I've used it before and it peels off easily - at least off of my old-school aluminum roof.
Ditto.
Chances are good that the screws have worked loose. I've had that problem happen twice on the same rig, so the last time it happened, I put thread lock compound on the screws.
44,029 PostsLatest Activity: Jan 19, 2025
