westend
Oct 13, 2014Explorer
You do worry a lot but in this case your thoughts are well placed. A leak is the #1 enemy of a TT. After restoring my Starcraft and using every possible way to seal against any leaking, I found two small leaks that were visible from the inside. That instigated me to do a pressurized leak test. The leak test turned up about 20 small leaks, pinholes, really. and a few spots around screws.
Here is a pinhole leak:
44,029 PostsLatest Activity: Jan 28, 2025
