westend
May 20, 2015Explorer
Justinb wrote:I'd use what ever size would do the job. Yes, you need to scrupulously clean the surface the tape adheres to. I scuffed it with a 3M scuff pad and cleaner. Final cleaned with lacquer thinner. Acetone would probably be more friendly. You must roll it, the adhesive is released in the compound of the tape when force is put on it.
Thanks for the idea!
Would you use 2" or. 4 inch externa bond tape around the whole edge? Would you get the cleaner and roller to put it on?
What type of calk do you use around the windows and doors?
Thanks Justin
I use the Geocel brand of tripolymer sealers on windows, doors, and siding trim. Geocel 2350 is equivalent to what I used but Geocel Proflex RV sealant is almost a twin.
44,028 PostsLatest Activity: Mar 15, 2025
