- mkirschNomad IIUnless the screw protrudes clear to the outside, it is just the exit point.
- WNYBobExplorerWell if it is in your closet, and I don't think it has rained in there, I would guess that it is not the source. Check outside trim for bad caulking, you probably have some wet or rotted wood behind and above the screw you found.
- Dick_BExplorerWas the screw high or low?
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 21, 2025
