โJan-05-2018 06:17 AM
โJan-09-2018 04:42 PM
โJan-09-2018 02:51 PM
tinstartrvlr wrote:
Heard a tale from someone who did a factory tour. He said the line workers had something like 22 minutes to complete whatever task their station required.
No wonder why things look like they were slapped together.
And then at the end of the line, if there are no OBVIOUS issues, the unit moves on. Then it's up to the dealer to deal with the fallout. And the customer suffers.
All about the bottom line. Crank em out and get em sold.
Sad really.
โJan-09-2018 06:55 AM
โJan-08-2018 11:04 AM
โJan-08-2018 10:46 AM
rbpru wrote:
Ever RV campsite i can recall had the electric hook up at the back end of the TT pad. Also, the full hookups were on the passenger side.
Most of the time we only need electricity so any location but the rear of the TT would be inconvenient.
โJan-08-2018 09:38 AM
rbpru wrote:For those that may not know, the exact locations of pedestals and power inlets are specified in art. 551 of the NEC. NFPA 1194 covers water, sewer and power locations on a site. Power entry points on an RV must be on the left side within 15' of the rear or can be on the rear on the left side. Site sewer and water connections must be on the left rear half of a site. Not sure what code/standard covers the location of sewer & water hookups on an RV but there must be one.
โJan-08-2018 08:46 AM
โJan-08-2018 05:54 AM
โJan-07-2018 05:33 PM
ScottG wrote:
No. 2 sounds like Arctic Fox trailers. They keep putting the water fill on the wrong side and the electrical at the extreme back corner.
Why is this the rule rather than the design exception?
I do know for a fact that NW has their engineers use their products and for that reason they are otherwise well thought out - at least on the inside.
As far as quality is concerned, I too have noticed the materials improving. Where they fail is in the execution. Way to sloppy in the construction and way too many stripped screws. This even after years of complaints by owners.
I think the real problem is they aren't assembled by people who use them.
โJan-07-2018 04:38 PM
Sad really.
Folks should do a few tours of RV assembly plants, then they would understand why there are problems. They might find that the idea of these things being designed, engineered or quality controlled is not part of the equation.
โJan-07-2018 06:48 AM
Sad really.
โJan-07-2018 06:47 AM
โJan-06-2018 09:25 PM
โJan-06-2018 07:05 PM
BadgerMcAdams wrote:
Do RV engineers and designers go RV'ing? Here is a simple test...
Go out and open the hood on your car...How easy is it to get to the spark plugs? The fan belt(s)? Heater and radiator hoses? Could you easily work on the vehicle if needed? The engineers and designers have probably never had to work on a car or truck they designed. Especially one that has had a few miles put on it.
I would imagine it is the same for the RV designers. They probably don't think about the "Where" when it comes to connections, only the "How" to fit every single option in a very limited space.
And if they do RV...Maybe they are Sadists who enjoy making it tough for people to connect up all the devices. Who knows...
