- smlfordExplorerI went to my dealer and gave them my vin also. I plugged in the new parts to confirm both the gps and sat radio worked which it did.
Next week I'll tackle the install.. - joro2548ExplorerI recently went to my Ford dealer and gave them s/n of my f350 and they matched the proper antenna and cable for my truck. Installing today and will see if it works.
joro - sbryanExplorer IIThanks to Joe for all the infoormation on the modification for the antenna.
Here are a few things I have learned after my first, failed, install.
There are several antennas, all with the Ford part # 10E893-A. But they are different and the Ford parts numberingsystem is a mystery to me. The first antenna I received was for "With Navigation System ; Global Positioning System Module (GPSM) part 893 $58.92." I have a Lariat Ultimate with Sat radio and navigation system. This part does NOT work with my configuration. After calling Ford and consulting with my dealer we determined that the part I needed is "HD Radio Broadcast ; Includes Attaching Hardware, AM/FM/Satellite Antenna Part 893B $42.33", seen on this diagram
This item is working fine with my configuration even though both antennas seem to have the same part number.
A few more notes on the install. I drilled a 5/8" hole in the plastic cowl and the antenna fits nicely through that hole. The space under the plastic cowl is very tight but I used a 10mm short socket and very small wrench to tighten the antenna bolt. As the bolt is tightened it expands the metal teeth on the antenna mount and I have a nice tight fit on the cowl. The rest of the install was a snap. Here's a shot of the wrong antenna and the mounting bolt.
Again, thanks to Joes for his work on this mod. - sbryanExplorer IIAfter consulting with Ford there are 3 different antennas, all with the 10E893 number but for my unit I need DC3Z-10E893-E. When I ordered I got part number 893-A.
Correction to the above. The 893-E module is NOT an external antenna, it is mounted up under the dash. The hockey puck antenna is either an 893-A or 893-B.
Still not getting Sat radio but the GPS works fine. Need to do more troubleshooting to find out why the sat radio is giving an antenna error message. - sbryanExplorer III have a 2013 F350 and just finished the install and verified the connections. The GPS is working fine but I am getting no Sirius XM reception. Head unit says antenna fault. Guess I'll need to check part numbers as well. The roof antenna is definately a different shape from the part number I ordered and installed.
- PowelligatorExplorer
CaFordGuy wrote:
Powelligator wrote:
CaFordGuy wrote:
I did it his mod, mainly for GPS. It works great. However, the part number listed above is for a Sat Radio only and does not work for GPS. (I tried it). Best bet is to take your truck's VIN to the local Ford dealer and have them look up the part number for a replacement for the antenna that is on your truck. Note that the Sat Radio only antenna is about $40 but the combo radio+GPS is about $65.
What year/make/model truck do you have? The part numbers I listed above are correct for a 2014 Ford Super Duty.
-Joe
I have a 2012 F350 Lariat. I bought and installed that PN. That Sat radio worked fine, the GPS did't. Went to the local Ford dealer and they verified that it was the wrong part, it was for an non Nav/GPS truck.
Model year 2012 used the Generation 1 Sync system. 2013 and up use Generation 2 Sync. That might be the problem. I've used the above part numbers in four installations (2013 and up Super Duties) with no problems. I have not moved the antenna in a 2012 or older.
-Joe - CaFordGuyExplorer
-Joe
I have a 2012 F350 Lariat. I bought and installed that PN. That Sat radio worked fine, the GPS did't. Went to the local Ford dealer and they verified that it was the wrong part, it was for an non Nav/GPS truck. - bikepsychExplorerSuccess! New antenna mounted. XM lives as does Navigation. Its not quite secure on the plastic as it is up on the roof so I need to figure out a way to secure it to the plastic by the windshield wipers a bit better. Perhaps some RTV around the edges. Open to suggestions.
Bruce - PowelligatorExplorer
-Joe - WVbassmistressExplorerI am going to tag along on this thread because in my mind it is similar.
I just took the plunge with an EZ Pass. Am I going to encounter the same problem with the TC overhang and the transponder? The instructions I got were to mount it up near the top of the windshield. Anyone on here use EX Pass. Our Northstar has the north/south bed configuration and really covers the truck cab.
Thanks
About Travel Trailer Group
44,028 PostsLatest Activity: Mar 12, 2025
