larry_cad
Apr 13, 2021Explorer II
Water and electricity isn't the problem. It's water and the corrosion that it makes. Actually electricity and corrosion isn't a super bad problem. Now, talk about electricity and high resistance and you have a problem. High resistance 12v connections caused by corrosion, with lots of amps available can create heat. Heat can cause fires. If that all happens, they you have a real problem.
Oh, and that does happen. Not often certainly. But then, how many times do you really want it to happen?
44,030 PostsLatest Activity: Jan 21, 2025
