buckarooman's avatar
buckarooman
Shurflo Revolution
Wahoo got my new pump in and wow apparently my old pump was dieing long before I built the winterize kit. This pump tends to take longer to build pressure but for the first time I have decent pressure at the faucets, I need to build about a 1ft long extension to get the water pipe back to a unfunky angel but I can now winterize and do that in the spring.
  • Ain't it cool when something happens better that you thought it would!!!!
  • It's hard to tell right now because I to have every thing opened up but I think so. Plus it doesn't run all the time like the other because it would loose prime, this one sat over night with the switch off and when I turned it on this morning it still had pressure.
