wgriswold
Sep 25, 2016Explorer
Slack in 7-pin Cord
Since I got my new truck last February it has been complaining about low battery voltage and now also tells me to check trailer wiring. I have taken it to the Ram dealer and they found nothing wrong with the truck. So I think the truck is smart enough to monitor the trailer.
On my last trip I had Autozone check the trailer batteries and they said they were defective. I replaced them but the problem is still there. So I think the problem is with the wiring on the trailer.
I am going to replace the 7-pin cord and plug. Several years ago the cord dragged and I repaired it. The plug is original and the spring type where the male plug is squeezed between two metal connectors and the squeeze connectors seem to be weak. So replacing them is a good next step in solving this problem.
So the question is, once the cord is stretched tight to reach the socket on the truck, how much slack should be added to account for turns? I am hoping there is some rule of thumb so I get it right. I can't just duplicate the current cord since the truck has a different position for the socket and the cord is now too short. I have been using an extension cord but want to eliminate that.
