xtruckerjim's avatar
xtruckerjim
slide out controller
Wilderness 29RL. I can't locate the slide controller. I've crawled around from one end to the other.
Anybody have a clue?
Jim
  • My Forest River slide controller was laying on the floor under the pantry cabinet. The only access is by pulling out the drawers below the shelving cabinet which is near the power converter. It was not mounted in any way until I mounted it to a vertical surface in a position that I could push the button & read the codes - I still have to remove the drawers.
  • Mine was just inside the entry door in a panel with a flop out door which had both awning and slide controls.
    Try here for info (hopefully).
  • I have no idea where your’s is, but just to give you an idea of what the possibilities are, mine is behind a panel that is held on by 4 screws you can barely see; underneath the breaker box/fuse box.
